Gab25
(Gabriele)
November 11, 2024, 6:45am
1
From some week when I start the autofocus macro the laser I think goes to down because it’s start to move up all the frame, do you have any idea or settings that I need to modify?
It’s strange because I didn’t modify anything in settings.
I’m using a Twooatrees TS2
Thanks!
parsec
(FerAS)
November 12, 2024, 11:23pm
2
You´re asking him to go down and focus the move is ok the function don´t, check if your auto-focus sensor is working fine clean dust contacts.
Gab25
(Gabriele)
November 13, 2024, 7:04am
3
Thanks for the reply. Do you have any suggestions to check the autofocus working fine?
parsec
(FerAS)
November 13, 2024, 7:02pm
4
Did you create your device by importing a TS2.lbdev from web or TF-card?
From the manual it seems auto for engraving but for cutting you have to edit macro with half material thicknesse.g. for 2mm material Z-1, for 4mm Z-2 and so on.
A few bits with cut settings
TwoTrees TS2 Laser Engraver Tips tricks files and mods
Gab25
(Gabriele)
November 13, 2024, 7:36pm
5
Previously from TF-Card and after from web but the problem is the same. I’m trying to cut 4mm and my macro is this:
$HZ
G91
G1 Z-2 F300
I’ve checked the cable for Z axis and also others but seems ok.
parsec
(FerAS)
November 13, 2024, 7:46pm
6
And autofocus for engrave is OK?
If you type in console $HZ and press enter where does laser head moves? and stop at limit switch?
Gab25
(Gabriele)
November 13, 2024, 8:03pm
7
Already with the homing $HZ cause me the problem.
I did a video here:
parsec
(FerAS)
November 13, 2024, 8:14pm
8
Post your TS2 engraver.lbdev.
Do you hear a click at the end when laser goes down? Your laser Z limit switch are in the top or bottom?
If top try reverse Z.
. doc
parsec
(FerAS)
November 14, 2024, 10:27pm
9
Did you change some GRBL settings? Maybe your (Z) Home direction is incorrect.
Gab25
(Gabriele)
November 15, 2024, 1:20pm
10
I’ve just tried and no changes, it’s still unfortunately does the same thing
parsec
(FerAS)
November 15, 2024, 1:25pm
11
Type $$ and press enter in Lightburn console window and post here the output.
Gab25
(Gabriele)
November 15, 2024, 4:51pm
12
[VER:1.1.2022122101:]
[OPT:PHSW]
[MSG:Using machine:LKS DLC32]
[MSG:Mode=STA:SSID=:Status=Not connected:IP=0.0.0.0:MAC=B8-D6-1A-9E-91-54]
[MSG:Mode=AP:SSDI=Laser_21649:IP=192.168.4.1:MAC=B8-D6-1A-9E-91-55]
ok
ok
$43=1
$0=10
$1=25
$2=0
$3=5
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=1.500
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$37=0
$39=0
$40=1
$41=1
$42=3.800
$100=80.000
$101=80.000
$102=533.330
$103=100.000
$104=100.000
$105=100.000
$110=10000.000
$111=10000.000
$112=300.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=200.000
$123=200.000
$124=200.000
$125=200.000
$130=451.000
$131=451.000
$132=63.000
$133=300.000
$134=300.000
$135=300.000
parsec
(FerAS)
November 15, 2024, 10:53pm
13
Did you change any GRBL settings? $130 and $131 and others?
If you press the focus pin do you hear a click?
Jog your laser head by hand to the middle of the Z axis then issue in console window G1 Z2. Does the laser move up or down?
If this guide helps:
https://wiki.twotrees3d.com/en/LaserEngravingMachine/TS220W/MachineCalibrationGuidelines
Also make sure the pin touches the material and not a void when auto-focus.
Report back.
parsec
(FerAS)
November 16, 2024, 11:01pm
15
2.Your video is not public.
3.It´s standard configuration.
Maybe you have a faulty switch.
parsec
(FerAS)
November 17, 2024, 10:25pm
17
Do you have a voltmeter to check continuity/Ohms at the plug on the end of the cord that comes from the switch or at the switch?
Also you can do a ramp test and focus manually.
Lenses, Usage and Ramp Test Focal Ramp Test. Finding the perfect focal point (smallest dot size) can be difficult. Many lenses have a threshold or manufacturing tolerance that can vary up to 2-3mm. Take a standard 2" lens for example, it's possible...
https://lahobbyguy.com/bb/viewtopic.php?t=428
system
(system)
Closed
December 17, 2024, 10:25pm
18
