Autosave quits after awhile
As the topic suggests, I have had autosave of a file quit working…
Yesterday I had a linux desktop crash for some reason. Lightburn had been running for a week or so and I had been using it to create with over that time. After the crash, I restarted and started up LB and reloaded the file I had been using (maps.lbrn) This file lives on a 4TB USB drive. ALL my work for the last week or two is completely gone. I knowI was using 1.7.xx branch but not sure which revision 00 or 01. I know LB was supposedly “autosaving” as it will block when it does (should have been my first clue as it was taking excessive time to save). I’ve had this happen before as well but thought I was doing something wrong or wasn’t sure if I’d done something, but MAYBE an error msg if the autosave fails which I have to assume is happening. Are you checking error msg’s from the actual function calls in c lib?
