I have an “old” AWC608 from lightobject shop
I would’like switch on/off my air assist with your switch in the lightburn software
But apparently the output signal doesn’t change on the motherboard awc608
Have you got an idea ?
Since I use the same controller I recall that someone else wanted to do this and the post got pretty detailed. So all this was discussed not long ago. I don’t recall if the thread was about air or exhaust fan. I tie both into a door switch.
I would try not to be distracted by manuals that might or might not exist and concentrate on inputs and outputs. Does a Lightburn switch change anything on the controller outputs? Your original post says no. Instead of providing a voltage could they allow voltage to be grounded? I wouldn’t hold up much hope that this is going to work.
I think the Trocen controller switches the supply voltage, not ‘sink’ it. So the solenoids to be connected to to the ground then to the controller. Unlike a Ruida, that sinks current.
This is from a Trocen AWC708 manual and seems to support that…
Just ‘assuming’ but I’d guess that OUT1 is equal to the ‘Status’ of the Ruida along with OUT2 equating to ‘Wind’. The Ruida ‘sinks’ to ground, the Trocen ‘supplies’ power.
