AWC708C Laser 1 and Laser 2 fires at the same time
Hi
I have an AWC708C and 2 lasers, 35 watts for engraving and a 130 watts for cutting.
my problem is, although I chose the Fill Layer Laser 1, Laser 1 and Laser 2 fire at the same time.
the DSP I have already tried to switch to 2 heads, no improvement.
greetings from Austria
Is this with 0.9.12? You didn’t mention which version you are using.
The new one
I downloaded it an hour ago
.13 loaded and problem identified. I have to select and activate laser 1 with enabled, click on laser 2 and deactivate enabled.
now only laser 1 works.
but there is still a problem, laser head 2 is 70mm further to the right, I have entered LB enable laser 2 offset 70mm, but does not work.
0.9.13 also included some fixes for the 2nd tube, so it’s quite possible it was both problems. :slight_smile:
I don’t think I am handling the tube offset for 2nd laser, so I’ll need to port that over from the Ruida code as well.
