Axis movement GRBL
Hello everyone and lots of patience and good ideas for Christmas preparations.
I need help. Lightburn Grbl setting
$100 – 100 - – it is a spindle with 8 mm / rev.
$101 – 20 - – It is a belt drive with 40 mm / rev.
$102 – 100 - – Not in operation
$110 – 2000 - –
$ 111 – 2000 - –
$ 112 – 2000 - –
$113 – 100 - –
The machine runs smoothly and cleanly. The travel paths without a laser are carried out precisely. The speed of the axes is the same for X and Y. I stopped this without a laser over a travel path of 300 mm. There is no deviation.
With a laser, the X runs as usual, the Y runs at about three times the speed. The approach points are adhered to. The result is a clean cut in X, in Y it is just a cut.
The order is carried out using a drawing created in Lightburn.
Where can I set the Y axis here.
What you want to change in Y?
Hello, I can’t solve the problem with my axis movement. The Y-axis runs faster than
drawn. If I move diagonally or only on the X-axis, the cut is carried out exactly. If I use G0 and let the axes run individually, the time and running distance are exactly right. If I use G1, G2, G2, the running speed is different. If I cut a square, the X-axis is cut cleanly, the Y-axis is only marked by a line, cut. The calculations for the movement are done in Lightburn, not on the control board. Or am I seeing this wrong? Will a complete reinstallation help? I am grateful for any tips. Greetings for the 2nd Advent.My English is not good enough, so I’m using Google translation.
If you make a 100mm square does the laser mark 100mm in each direction?
The laser cuts in the X direction, but only marks in the Y direction. If I rotate the rectangle by 45 degrees, the rectangle is cut cleanly.
Since the speed in the Y-axis is significantly higher than the X-axis, the laser does not cut, it only marks. In the interaction of both axes, for example diagonal, the laser works exactly as well as in the X-axis.
As a start type in console $RST=$ then try again and report back if you need more help.
Thanks, I’ll try that
Hello, I reset the settings. ($RS=$) Set everything up again and tested it. No success. Did the whole thing a second time. No success. This is what the result looks like from both sides. The Y axis runs too fast. See photos. Tested:
G0X300 - runtime 10 seconds.
G0Y300 - runtime 10 seconds.
G1X100 - 72 sec
G1Y100 - 14 sec
With G1 the runtime is in a ratio of 1:5. So exactly as set under $100 and $101 1:5.
Where can I change the settings now? I always think changing $100 and $101 is not the solution. Is it advisable to repair Lightburn, where can I find a program? Should Lightburn possibly be reinstalled?
Thanks for any tips
Type
$$ enter
$I enter
in console window then copy/paste here the output.
Run the file in this post and post a photo of the output.
Auf Verbindung warten …
Grbl 1.1f [‘$’ for help]
ok
Monport
[VER:1.1f.20230316:]
[OPT:VMZHL,35,254]
Target buffer size found
ok
$0=10
$1=25
$2=0
$3=6
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=25.000
$25=500.000
$26=250
$27=2.000
$30=1000
$31=0
$32=0
$33=1
$34=1
$35=1
$36=1
$37=1
$38=10
$39=0
$100=100.000
$101=20.000
$102=800.000
$110=2000.000
$111=2000.000
$112=100.000
$120=20.000
$121=20.000
$122=20.000
$130=320.000
$131=820.000
$132=200.000
ok
$I
Monport
[OPT:VMZHL,35,254]
ok
![WhatsApp Bild 2024-12-13 um 14.28.10_95fd2381|375x500](upload://hKof530Dula0J78zCdYSd4R1xiv.jpeg
Thanks for any tips. Have a nice weekend
As a start set $32=1. I´ll check later your pic and the rest of the settings.
I would be checking belt tension and other areas for looseness.
Guide to mechanical adjustments and maintenance
Danke für den Tipp.
Habe ich alles neu eingerichtet. kommt kein anderes Ergebnis. Mich stört das Verhältnis 1:5, wie unter $100,$101. Bei der Riemenspannung könnte es eine geringe Abweichung sein , denke ich.
What machine is this? Your profile mention Sculpfun S10.
What GRBL settings did you change when setting things up?
As your rot/linear mechanics are different your speeds and acceleration rates will be different for each axis. For now keep the Y settings because the implicit lines seems to be straight. Try changing $110=1000.000 $120=10.000 one at a time. Lower these values by 10% to 20% each time until all is ok. Notice however that your laser interpolation moves will become slower.
Test and report back.
Read all and the Quick Guide at the end
https://github-wiki-see.page/m/gnea/grbl/wiki/Grbl-v1.1-Configuration
Hello, I have tried many options. I cannot find a solution. At a speed of 500mm/sec, the running time of both axes is the same. But I cannot cut with that. Is there a way to set the speed of the axes separately? If I set the speed to 100mm/min, the X-axis runs at 100mm/min and the Y-axis at 500mm/min. Lightburn allows drives with different speeds ($100, $101, $102) but I cannot find a point where I can compensate for this speed. Do I have to change the belt drive to a spindle? Then I need a spindle with the same pitch. I am desperate.
Thanks for any tips and happy holidays to everyone.
$100, $101, $102 are not speeds, it´s a setting fine tuned so that 1mm move in software translates to 1mm move in your machine.
May you Make the changes I asked and report back?
I have followed your advice. No useful result. All working speeds below 500mm/min move the axes at different speeds. From 500mm/min the axes are in synchronism. The table below shows this.
Thank you for any further tips.
I can’t insert an Excel table. Please give me an email address. Thanks
