The link is to a beacon probe
It currently works with klipper can scan 10k points and create a bed mesh
Is this soemthing that could be ported into light burn
The way i see it this runs off usb so why not run it off the co outer that has more power
Put ur design on the generated image then light burn sends agimented gcode to offset elevations
Future ideas could be using the software to srt depth of cut and having the probe check depth between layers
Thoughts ?
