Available now at https://shop.beambuddy.xyz
The Beam Buddy high resolution laser head is a replacement head for your laser. It allows you to engrave at a much higher quality than the stock laser head that came with your laser. Its design makes the laser beam more focused into a smaller focal spot than the standard laser head, which makes the engraving result more detailed. It is suitable for engraving high precision photos and also a good performance on 3D engraving. The higher resolution creates a significant increase in detail on photographs. Your creations will be incredibly life like and produce very accurate reproductions of your photos. Ships complete with lenses and fully assembled.
Features:
Spaced lenses prevent overheating and lens damage that other compound lens systems are susceptible to
Silicon washers under retaining rings to prevent damaging lenses
Custom manufactured 20mm diameter USA CVD ZnSe AR coated lenses from ii-vi infrared rated for 150W
All aluminum construction with blue anodized finish
3mm focal length from bottom of cap
Variable air assist valve
Maximum resolution of 800dpi on anodized aluminum
Easy swap from stock to Beam Buddy and back again
The K40 version works with the stock K40 head as well as the Light Object air assist head
Can be used to cut materials up to 3mm in thickness, great for doing inlays
