Hi. I’m new to laser world. I have a Jinsuko LC-60A and I’m trying to set up Lightburn. Is there anyone willing to meet with me virtually to help get started? I am totally lost.
Do you have a trial version of Lightburn installed?
Will Lightburn connect to your machine?
Need a little more information to help much further…
this is the laser machine
and can use LB, you only have to download thei manual at this address in which there are drivers for windows and the manual that explain step by step what you have to do to connect you engraver to LB
you can find driver installation at page 18 of the manual followed by Ligthburn’s installation
Thanks. I’ve got the driver downloaded now.
I have downloaded Lightburn and installed drivers as per my machine. The laser goes through the motions but doesn’t actually do the engraving. I previously did a test and it worked but now that I have set up a project, it doesn’t engrave. I tried different speed and power settings but none of them work.
Yes,I’ve already downloaded the drivers. I tested it it before but now that I have my project to engrave, my laser isn’t firing. It goes through the motions but it won’t engrave.
