My first time asking a question so be kind. So, I can get the blue dot to bend text to show up with no problem but my problem is that even the slightest mouse movement results in a highly exaggerated response on the text. I can’t make it bend “just a little” it goes from a straight line to a tight little ball almost instantly. How can I slow the rate of bending to achieve more precise control?
Pull the blue dot farther away from the center of text. That should effectively provide the effect of lengthening the lever for bending of the text, thus allowing for more fine grained control.
Duh! Now you know why I don’t work for NASA. Thank you very much for the solution.
