Hello. I have the Ortur LM2 Pro S2 and would like to start using a camera setup. I would like suggestions with similar setups on what to get. The only limitation I have is I only have 16" above the laser to mount a camera. The laser in on a counter top with cabinets above. I could mount the camera on the bottom of the cabinet if needed.
Thank you.
Don
Maybe this helps:
If you click Help > Camera Selection Help a new window opens with a bit more info.
Thanks. That give me some good info. I was hoping to hear from someone that had a setup that works good. I will keep looking. I do have a Web cam, guess I can play with that some. I just feel that Iām limited on height over the laser.
Don
