Hi,
I’m trying to build a custom DIY DTF roll-to-roll film-cutting machine. I was inspired by this lady who cut a single film sheet with her CO2 laser.
As you can see in the video, the CO2 laser cuts the film very fast and without charring.
I hoped to use Sculpfun’s S30 33w diode laser to achieve a similar result. Unfortunately, even with air assist, I’m getting a lot of charring.
I asked ChatGPT about the differences between diode lasers and CO2 lasers and received this response:
“CO2 lasers operate at a longer wavelength (typically 10.6 μm) compared to diode lasers (usually in the near-infrared range, around 0.8-1.0 μm). The longer wavelength of CO2 lasers is more readily absorbed by a wider range of materials, leading to cleaner cuts and less charring.”
The problem I face is that I would rather not work with a DYI CO2 laser. Between dealing with the CO2 tube, mirrors, cooling, limited lifespan, and being forced to use an enclosure with a CO2 laser, a diode laser would be much easier if I could get it to work without charring.
I’m thinking about trying Sculpfun’s new S70 70w diode laser. The gantry is much faster, and the laser is far more powerful.
I’m new to lasers. Do you think the extra power and speed of Scuplfun’s S70 laser will result in less charring? Or will I be forced to use a CO2 laser to get no charring?
Any advice is much appreciated.
Wyatt
