Best Online Box Maker
Hi and thank you for your time and suggestions.
I’m a newbie to laser and Lightburn.
Can you please suggest some of the best online box makers that I as a newbie will easily get a hold on? I’ve done some searching and some seem very easy but, for some reason have lower ratings.
Thanks so long.
There’s not really anything to rate at an online box creator. Either you like and use it or not, ie. If it fits your needs then everything is fine.
I started with boxes.py and used the program in last 6 years … didn’t need anything else. However, the simple boxes I make from the bottom myself, with Lightburn.
Thank you very much for the reply. I hope to be able to do my own as well one day. It is the finger joints that I think I will have to practise one in the future.
Thanks again for your advice. I will have a look at boxes.py
I also use Gallery - Boxes.py and found it the best one I discovered so far.
…you are welcome. Finger joints for boxes are likely one of the first things everyone would like to learn. They are important but also fun to work with. :+1:
