I got tired of a million different power bricks for all the auxiliary power bricks a for lights, routers, and small equipment and i have a bunch of different power supplies so I built a power distribution panel with, 48, 36, 24 vdc all ran to a terminal strip, all with shared ground and shared negatives to help isolate.
I’m goin to add meters to each to keep an eye on usage and wattage. tight now they draw a total of 1.2 amps . I will put in mounted plug banks through the enclosure and then run out custom low voltage power leads and some breakers for what I need .
