Oh! I forgot! I have a confused Longer Ray5 10 Watt!
Not exactly sure what you asking advice on.
What was it you used for the redish one?
My apologies and thank you for responding!
If you zoom in you can see there are parts that are darker than the rest. I am wondering if it is due to this being an ink sketch I scanned in, uneven spraying, etc, (the top one).
It was the second tile I had done and it’s matte. Would that make a difference?
The reddish one is actually copper but it’s Mica I am still working out the kinks in how much I can push it before it clogs the sprayer.
Hi Robin, Your tiles look similar in quality to my best ones. I have found that if the image looks light it is usually due to a too thin coating of Titanium Oxide.
Can you elaborate on the copper colour mica addition?
Thank you! Yes I can. Mica is a very fine powder dye. The copper color resulted from having put the sprayer from the TD mixture in the cup with the antique gold. I’ll look for the tiles that I have been testing it on.
Mixing any color with the TD will still result in a black scan if you use too little but it will have a tint to it. Accidently mixing a little with antique gold mica results in copper.
Brand matters too. It dries fast so I have one shot if I have a hope of an even cover. It seems to prefer isopropyl alcohol to ethanol as well.
Give me a few moments, a prayer my laser behaves, and I will upload a new engraving.
Thanks Robin, I will do some experimenting as I have a box full of Chinese mica powder colours to try. I had no luck at all doing the normal engraving and adding the mica powder to parts of the i age for a second laser pass. It either blows away or burns.
It’s not an exact science though I should try harder to measure. I do know if you want it to really stay it has to be thick and not lumpy or it jumps
The spoon and mica
This one was late last summer:
This was when my laser just stopped. Guess it was tired lol but I was working with blue mixed with TD
I definitely feel the pain on no luck! Good luck!
Add regular rubbing alcohol and turn off the air assist. That should help. If you are using Let’s Resin brand it doesn’t engrave well. It’s too light in weight
I have tried ethanol with my TD and distilled water mix making the airbrushed coating application faster, but the fumes in my small workshop get a bit much to bare. Preheating the tiles on my vertical hotplate works fast enough with a simple water and TD mixture. Hopefully the mica addition won’t clog my nozzle faster than the TD does.
If this works, the next challenge will be obtaining near perfect positioning between multi stage / multi colour coatings and engravings.
Literary Brand Antique Gold Mica Powder dye that I had put the end of the sprayer from the bottle of titanium dioxide. A little of the TD will change the color. A lot of it will burn black with a tint to it.
This one hasn’t been scrubbed and I am running one on a clean tile but the focus is on the amount of
Mica left when it’s only combined with alcohol.
Now back to your expert advice. Mineral water… I have never heard of this but I am going to try it.
I also noted you mentioned warming the tile. I have a resin heating pad and a candle warmer but would like to know more about how this part works.
Your tiles are superb! Mine are hit and miss.
If this works diode lasers will have achieved something akin to fiber lasers. Color ![]()
Is your finished engraving strongly attached to the tile surface the same as the TD only engraved coating?
My tool for warming the tiles prior to airbrushing the TD is a cheap warming tray bought at a recycle store that looks a bit like this.
I have it almost vertical in my spray box and simply lean my cleaned tiles against it for spraying.
Yes as long as it’s thick enough with no lumps. It will have lumps if you are not careful.
I cleaned the last one with a Mr. Clean wipe, Clorox Clean up wipe, ethanol, acetone, and for good measure Dawn PowerShot. The only fading was in the whiskers of the lion.
Unless you plan on running quite a few of the same color it wouldn’t be cost effective as the dye that is not engraved just sits on the tile.
I spray the mica tiles vertically then flip them up quickly before it reaches the bottom. It will separate and it does dry really quickly so you have to be fast.
How does warming the tile effect the TD?
Hi Robin
Warming the tiles has no effect on the TD, it simply speeds up the water evaporation. The TD coating can easily be scratched off if not handled carefully before engraving. After engraving and rinsing of the un engraved TD with tap water, the image is permanently fused to the tile and is even dishwasher safe.
