I have played around a bit in LB and searched the forum to try to find an answer to my problem. I have a bitmap imported that I traced to get the outline. The bitmap is a law enforcement badge and has a white background. I successfully traced the outline of the badge but cannot figure out how to get the outline vector to appear in front of the bitmap so I can place it correctly. I tried both moving the vector to the front of the drawer and moving the bitmap to the back of the drawer but the vector stays behind the bitmap. Is there a way to bring the vector to the front? Thanks!
I think if you turn off output in the layer window for the bitmap this will let the vector be shown in front.
That was it! Thank you. I knew it had to be something simple!
