Blackbox X32 - connects, will not function in Lightburn
Hello group… Im sure someone has come across this and I am just not finding it in the forum. Just finished building an Acro1015 machine with the X32 Blackbox. Tested everything in Openbuilds control and it was flawless. I went into Lightburn, it did not automatically find machine so I set it up manually. Once it connects to the Port it shows GrblHAL 1.1f and is giving me a failed to initialize SD card warning.
The machine will not move, will not home. You can hear the motor engage when the COM4 connects but that is it. I am currently on Lightburn 1.4.04, not sure if this is creating some of the connection issue.
Lightburn Screenshot
It appears you are connected. There is no SD card in Lightburn, so it has nothing to do with this error. I suspect the error is what is keeping your machine from responding to Lightburn. The startup procedure for the laser has not completed.
Try another SD card, or reseat the current one?
The SD card error is from the BlackBox. It should definitely have an SD card in it. Mine came with it. But before you can use your machine with LightBurn, you need to select correct GRBL profile. I use OpenBuilds LEAD 1010 as the laser machine, so I use their CONTROL utility to select “OpenBuilds LEAD 1010 with LaserModule” before I can use the LightBurn.
Also, LightBurn 1.5 works significantly better than 1.4, so you may consider an update.
[08:40:32] [ connect ] Attempting to detect Controller (2): (Ctrl+X)
[08:40:32] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
[08:40:34] [ $$ ] $0=10.0 ;Step pulse time, microseconds
[08:40:34] [ $$ ] $1=255 ;Step idle delay, milliseconds
[08:40:34] [ $$ ] $2=0 ;Step pulse invert, mask
[08:40:34] [ $$ ] $3=0 ;Step direction invert, mask
[08:40:34] [ $$ ] $4=0 ;Invert step enable pin, boolean
[08:40:34] [ $$ ] $5=7 ;Invert limit pins, boolean/mask
[08:40:34] [ $$ ] $6=1 ;Invert probe pin, boolean
[08:40:34] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield
[08:40:34] [ $$ ] $9=1 ;PWM Spindle as bitfield where setting bit 0 enables the rest
[08:40:34] [ $$ ] $10=511 ;Status report options, mask
[08:40:34] [ $$ ] $11=0.010 ;Junction deviation, millimeters
[08:40:34] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
[08:40:34] [ $$ ] $13=0 ;Report in inches, boolean
[08:40:34] [ $$ ] $14=0 ;Limit pins invert, mask
[08:40:34] [ $$ ] $15=0 ;Coolant pins invert, mask
[08:40:34] [ $$ ] $16=0 ;Spindle pins invert, mask
[08:40:34] [ $$ ] $17=0 ;Control pins pullup disable, mask
[08:40:34] [ $$ ] $18=0 ;Limit pins pullup disable, mask
[08:40:34] [ $$ ] $19=0 ;Probe pin pullup disable, boolean
[08:40:34] [ $$ ] $20=0 ;Soft limits enable, boolean
[08:40:34] [ $$ ] $21=1 ;Hard limits enable, boolean
[08:40:34] [ $$ ] $22=0 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
[08:40:34] [ $$ ] $23=3 ;Homing direction invert, mask
[08:40:34] [ $$ ] $24=100.0 ;Homing locate feed rate, mm/min
[08:40:34] [ $$ ] $25=1000.0 ;Homing search seek rate, mm/min
[08:40:34] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
[08:40:34] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
[08:40:34] [ $$ ] $28=0.100 ;G73 retract distance, in mm
[08:40:34] [ $$ ] $29=0.0 ;Step pulse delay (ms)
[08:40:34] [ $$ ] $30=255.000 ;Maximum spindle speed, RPM
[08:40:34] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM
[08:40:34] [ $$ ] $32=1 ;Laser-mode enable, boolean
[08:40:34] [ $$ ] $33=5000.0 ;Spindle PWM frequency
[08:40:34] [ $$ ] $34=0.0 ;Spindle off Value
[08:40:34] [ $$ ] $35=0.0 ;Spindle min value
[08:40:34] [ $$ ] $36=100.0 ;Spindle max value
[08:40:34] [ $$ ] $37=0 ;Stepper deenergize mask
[08:40:34] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean
[08:40:34] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean
[08:40:34] [ $$ ] $43=1 ;Homing passes
[08:40:34] [ $$ ] $44=4 ;Homing cycle 1
[08:40:34] [ $$ ] $45=3 ;Homing cycle 2
[08:40:34] [ $$ ] $46=0 ;Homing cycle 3
[08:40:34] [ $$ ] $62=0 ;Sleep Enable
[08:40:34] [ $$ ] $63=3 ;Feed Hold Actions
[08:40:34] [ $$ ] $64=0 ;Force Init Alarm
[08:40:34] [ $$ ] $65=0 ;Require homing sequence to be executed at startup
[08:40:34] [ $$ ] $70=7 ;Network Services
[08:40:34] [ $$ ] $73=1 ;Wifi Mode
[08:40:34] [ $$ ] $74=Landline ;Wifi network SSID
[08:40:34] [ $$ ] $75=password ;Wifi network PSK
[08:40:34] [ $$ ] $100=199.100 ;X-axis steps per millimeter
[08:40:34] [ $$ ] $101=199.100 ;Y-axis steps per millimeter
[08:40:34] [ $$ ] $102=199.100 ;Z-axis steps per millimeter
[08:40:34] [ $$ ] $110=4000.000 ;X-axis maximum rate, mm/min
[08:40:34] [ $$ ] $111=4000.000 ;Y-axis maximum rate, mm/min
[08:40:34] [ $$ ] $112=4000.000 ;Z-axis maximum rate, mm/min
[08:40:35] [ $$ ] $120=700.000 ;X-axis acceleration, mm/sec^2
[08:40:35] [ $$ ] $121=700.000 ;Y-axis acceleration, mm/sec^2
[08:40:35] [ $$ ] $122=700.000 ;Z-axis acceleration, mm/sec^2
[08:40:35] [ $$ ] $130=810.000 ;X-axis maximum travel, millimeters
[08:40:35] [ $$ ] $131=730.000 ;Y-axis maximum travel, millimeters
[08:40:35] [ $$ ] $132=90.000 ;Z-axis maximum travel, millimeters
[08:40:35] [ $$ ] $320=grblHAL ;Hostname, max: 64
[08:40:35] [ $$ ] $322=192.168.5.1 ;IP Address
[08:40:35] [ $$ ] $323=192.168.5.1 ;Gateway
[08:40:35] [ $$ ] $324=255.255.255.0 ;Netmask
[08:40:35] [ $$ ] $325=23 ;Telnet port
[08:40:35] [ $$ ] $326=80 ;HTTP port
[08:40:35] [ $$ ] $327=81 ;Websocket port
[08:40:35] [ $$ ] $341=0 ;Tool Change Mode
[08:40:35] [ $$ ] $342=30.0 ;Tool Change probing distance
[08:40:35] [ $$ ] $343=25.0 ;Tool Change Locate Feed rate
[08:40:35] [ $$ ] $344=200.0 ;Tool Change Search Seek rate
[08:40:35] [ $$ ] $345=200.0 ;Tool Change Probe Pull Off rate
[08:40:35] [ $$ ] $346=1 ;Restore position after M6 as boolean
[08:40:35] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask)
[08:40:35] [ $$ ] $384=0 ;Disable G92 Persistence
[08:40:35] [ $$ ] $396=30 ;WebUI timeout in minutes
[08:40:35] [ $$ ] $397=0 ;WebUI auto report interval in milliseconds
[08:40:35] [ $$ ] $398=35 ;Planner buffer blocks
[08:40:35] [ $$ ] $481=0 ;Autoreport interval in ms
[08:40:35] [ $$ ] ok
[08:40:35] [ $I ] [VER:1.1f.20230501:leadmachine1010laser]
[08:40:35] [ $I ] [OPT:VNSL2,35,1024,3,0]
[08:40:35] [ $I ] [AXS:3:XYZ]
[08:40:35] [ $I ] [NEWOPT:ENUMS,RT+,REBOOT,TC,SED,RTC,WIFI,SD]
[08:40:35] [ $I ] [FIRMWARE:grblHAL]
[08:40:35] [ $I ] [NVS STORAGE:*FLASH]
[08:40:35] [ $I ] [DRIVER:ESP32]
[08:40:35] [ $I ] [DRIVER VERSION:230501]
[08:40:35] [ $I ] [DRIVER OPTIONS:4.3.1]
[08:40:35] [ $I ] [BOARD:BlackBox X32]
[08:40:35] [ $I ] [AUX IO:1,0,0,0]
[08:40:35] [ $I ] [WIFI MAC:xx:xx:xx:xx:xx:xx]
[08:40:35] [ $I ] [IP:0.0.0.0]
[08:40:35] [ $I ] [PLUGIN:WebUI v0.17]
[08:40:35] [ $I ] [PLUGIN:SDCARD v1.09]
[08:40:35] [ $I ] ok
[08:40:35] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
[08:40:35] [ $G ] ok
[08:40:36] [ connect ] Firmware Detected: grblHAL version 1.1f dated on COM3
