Blackbox X32 not shutting off between cuts
Hey all, I have Lightburn setup on my CNC machine with an Blackbox X32 Controller. Lightburn will run perfectly after homing but with one caveat, the laser stays on at low power when traversing between cuts, thus leaving a trail.
Is this a GRBL setting issue? If so what do I change and how do I revert back to original settings for ht controller after Im done with Lightburn?
Thanks
This doc may help.
Thank you sir. That worked perfectly.
