Blue laser not coming
I have Sculpfun s9… the laser module is moving accord to the cut area… but the blue light (laser is not coming) I’ve unplugged n plugged all the wires… NEED HELP URGENTLY
Does the fan still work? Did you check the signal cable (test conductivity of the wires)?
Yes the fan is still operating
Then do the 5V test as explained here: Guide to mechanical adjustments and maintenance
I’ve done the 5v test. The laser is coming.then I do job as usual , at the beginning the laser is coming after moving to another place(according to the job ) the laser stopped only the module is moving
Then I suspect the cable is broken then. If it stops at certain positions, it’s usually the cable causing it.
