Boeans lightburn version 1.3.01
Hey
Yesterday I was helping someone with Bolean, when I pressed the Bolean to the left of lightburn, she opened a screen that you could use Bolean, I don’t get that screen, and we both have 1.3.01 version of lightburn, do I have to set something for me to get that window???
CTRL +B brings up the boolean assistant in windows.
Hotkeys
Hotkeys - LightBurn Software Documentation
This menu is “only” in the tools menu, it could be that Santa Claus could also conjure it to the menu on the left side, together with the 4 other boolean operations. :thinking: :santa: ??
However, cmd+B is also an easy way to start the assistant.
CTRL + B do not open the assistant
and tools boleans assistant is gray
afbeelding
why do this not work with boleans
i have it now,Melvin Isken has helped
Thanks Melvin en others Thanks
When they are grayed it out usually means the shape is not closed.
Yes it work now with help from Melvin Isken,
Thanks for all for the help thanks
I see no ‘help’ from Melvin Isken… I’d be in sad shape to hope that would help me fix the same issue on my machine.
What makes this work is that you explain the ‘solution’ and mark it solved. Others looking for help won’t need to do anything but read the fix…
Glad you’re up and running…
Melvin had help from facebook.
it was a wrong design, which had to be adjusted, and with convert to path, and with the nodes function, a lot of hassle, and with the bolean assist, but finally succeeded.
Thanks everyone here on lightburn also helped well, was in the same direction that I had to look.
Thank you Thank you all
