Is there something I am missing? Perhaps an Issue with SVG´s that have overlapping lines? Is there any other way to easily achieve what I am trying to do?
That should be the required files. Edit: I used the upload feature, but it has not worked properly. I can import my SVG just fine, and the Laser Preview shows that every single Line is recognized in Lightburn.
LBRN: booltest.lbrn2 (44,6 KB)
Left SVG:
Right SVG:
I believe the issue you having is the SVG is a collection of rectangles, so you will get the same behavior if you ungroup the “wall” pattern, select it all and do a “weld”
The resulting shape is this, on Ungroup, Weld
Now not 100% sure on why this is.
HOwever heres an interesting excercise
Select your shape, > convert to bitmap 500DPI
Then convert back to the path
As a 2nd thought. Probably “welding” the pattern could be easier on your vector pre work in InkSpace?
Seems to me The boulean function gets a bit confused - or maybe its doing what we are asking it to do.
Specially if boolean ignores “group” as a whole unit and sees each individual small rectangle as a unit within the BIG shape.
Thank you for the quick response, but unfortunately I wasn´t able to reproduce your steps to create my Boolean:
1.Select the Wall Pattern
2.Convert to Bitmap 500dpi
3.Converting back to path is now greyed out
I am very unexperienced with Inkscape/Vector Files, I usually do my Sketches in FreeCad, which is why I just created Tile Clones of Rectangles which I thought would be a quicker way to get my desired Pattern.
Now you have a new Image, the vector disapeared
Select it → right click → Trace image ( i think i miss guided you earlier with Convert to path)
Treshold 250, cutoff 0
Now you have a Image and a vector
Delete image and use vector for boulean
There is a downside though, as Lightburn cannot centerline trace, you have 2 lines. So would be ideal to do this on InkSpace
This is a clunky workaround
Following your Steps has worked perfectly, but as you´ve said, its probably way easier to make a proper SVG in Inkscape, and it won´t have double lines.
After manually creating rectangles and combining them, and not beeing able to ungroup them anymore In Inkscape, Lightburn still seems to recognize them as Rectangles and can ungroup them, and using your workaround just seems to create Double Lines again.
I recreated the pattern using lines instead of rectangles (Edit: While not overlapping the lines in any way), combined them, now I am completly unable to use the boolean tool when selecting the circle and the pattern. Is there a more reliable way to achieve what I am trying to do? Is Inkscape the right tool for this?
Also tried your workaround, sadly there are also gaps.
Edit 2: Also tried creating the Pattern using Lines in Lightburn itself, the boolean option is greyed out again. booltestlines.lbrn2 (7,0 KB)
Would you mind elaborating further, or reproducing it and sending a sceenshot? I am unable to convert it to Path in Lightburn, or are you talking about Inkscape?
Duplicate (CTRL+D) the circle, then deselect it, then select the brick wall, select the duplicate circle again, then go to “Tools” > “Cut Shapes” (Alt+Shift+C), and, lastly, delete the inner portion.
Thank you so much, this is exactly what I was looking for, but there apears to be overlap after using the cut tool, is this just visual or will it actually overlap when I engrave the shape?
There will be an actual overlap when you engrave this if you leave those lines as they are (sometimes this occurs due to the tolerances LightBurn works with for the Boolean operations, Cut Shapes, and other tools). They are so small that they might not be visually apparent when you actually score these lines, so it might be fine just to leave them alone.
To get rid of the overlap, you can also use the “Edit Nodes” tool to trim them back to where they intersect with the circle. Make sure they’re ungrouped, then select them, hover over the overhanging parts of the lines, and press “T” to “Trim” them.
Because of the way this brick pattern was made, you’ll need to do that twice for places where there are two overlapping lines.
You should also make sure you have “Remove Overlapping Lines” enabled in your Optimization Settings, so those lines aren’t output twice to your laser.
