Borax and smearing after engraving?
I have a simple problem. Borax and smearing after engraving. How do you solve this problem? Thank you.
Tomas, a picture is worth more as 1000 words :wink:
It’s more of a general question, because if I etch on borax-coated material and then run my finger or a rag over it, the product smears, like soot… :grin:
When I have soot on the engraving or the edges when cutting, I use technical alcohol and cotton cloths.
It is soot because you just burned the wood. You are not converting the borax to black. I skip the borax and just wipe the wood with a microfiber cloth. Others use isopropyl alcohol (sometimes stated as IPA) and a cloth.
Don’t touch it. Blow it off with some air and SPRAY a clearcoat. After several coats you could sand lightly to get roughness off.
