Boss Laser not engaging air assist
I have a Boss Laser 3655. Or rather the company i work for does. Up until yesterday it ran fine, now when I go to run a cut on it, it goes through all the motion of cutting. Tube engages, the head moves as if the cut is going on, but its not pushing any air. I have verified that I have the minimum 40PSI, but its just not using it. So its not cutting anything.
Ive reached out to Boss Laser, and they told me theyre super busy and a rep will reach out eventually. Is it possible the solenoid has failed, or something similar.
I dont have a wiring diagram, unfortunately.
The controller seems to be supported by Lightburn as a Ruida type. Can you look inside the electronics cabinet and see what name and model it’s inscribed as? Red arrow points to my Ruida controller.
I have a Ruida and mine has two levels of output. It run a low pressure when engraving and a high pressure when air assist for that layer is on.
If I make it a single turn on/off then the solenoid it connected to +24V and the other pin to Wind on the Ruida. When active, layer is executing and air assist is enabled on that layer, the Wind terminal sinks the +24V through the coil to ground. Basically it takes the open side of the solenoid to ground, completing the circuit and engaging the solenoid.
Make sense?
:grinning_cat:
