Boundary concerns
Hi everyone
I have a problem with my twotrees ts2 10w.
It is configured in 450x450MM, the home works perfectly, the 2 limits switches too.
But when I want to send it to the end of the Y or Y axis, my machine derails and makes a lot of noise.
I think there is a mistake in the famous 450x450mm.
I tried automatic and manual settings, nothing changed.
I think it’s a story of either too big a work size (manufacturer data) or a story of soft limit.
How to do it, it will damage my machine by force!!
What adjustment should I make and with what values?
Thank you for your help!
There are several ways to find the TRUE size of your work area, the way I would do it, is set move interval 100mm, Home machine, for a 450mm axis move 4x100 then set move to 5mm and count how many times you need to move until it hits then subtract 1 and do the math.
Thank you very much I will try, but my problem is something else, my Maxhine sometimes goes to +x and +y, and then makes a lot of noise and gets damaged, its original size is 450x450 mm. but it doesn’t work!
