Im setting up a brand new K40+, Ive realigned the mirrors and checked the tube all good with test button on console. Ive cut out a few pieces without issue.
turn on the machine day 2 and I have no laser. mA display shows 0.0 while the software is running a project. It frames and runs the project as it should just wont cut anything? plenty of water in the tank and pump is running?
The K40+ is aligned from the factory and all the mirrors have been glued in position as far as I know. So if you changed that setup, did you also touch the power supply?
First, I’d measure if those still supply the required power. And, the standard question: are all safety measures released? Emergency stop, door sensor,…?
