I’m new to using a diber laser so im not sure what im doing wrong. I have a 50w cloudray fiber laser and have had success with slate and steel, but i can’t get any kind of mark to appear on brass.
I’ve made sure the distance is right and have tried lowering the speeb and raiseing the power but its like the laser wont bite into the brass.
Most of the issues with fiber is they are not focused. You can focus them using sound, the loudest the better.
If you’d filled out your profile, I could help you more, but give us the type of machine, lens length, along with it’s power rating. Is it a MOPA type?
Fiber machines are pulse machines, so it’s difficult to compare them.
If the machine was in your profile we could all see what you have, and this would be unnecessary.
One more thing worth checking, Tim: a lot of brass blanks sold for gifts and trophies come with a clear lacquer coat, and a fiber laser will not bite through it at normal marking settings - it behaves exactly like you describe, no mark at all. Wipe a small corner with acetone and run your test on that spot. If it marks there, strip the coating off the whole piece (acetone wipe or a quick pass with fine sandpaper) and you are good. If it still will not mark on the cleaned spot, then it is focus or settings as jkwilborn says - a material test grid with a couple of passes usually finds it.
