I’m having problems with broken text. This attached file, is from months ago, and was a perfect engrave, and now the text is all broken, as well as the cross. It looks like most of my saved files are this way and same issue with current that I am working on. Have I mistakenly changed a setting?
You didn’t attach a file, just an image (just mentioning that in case you intended to attach the file as well). I don’t see anything wrong with the image, though it’s using coarse rendering instead of smooth:
That will affect how it looks in the editor, but not what is sent to the laser:
That was exactly what it was, must’ve changed that by mistake at some point. Thanks so much for your help!
