BUG: Grid Array (Shift by Half)
It’s been a hot minute since I’ve been on the forum but I have definitely been using LightBurn! Still amazing software. Anyways, I think I found a bug (at least I would consider it a bug.)
Create Grid Array > Shift by half (either vertical or horizontal)
This will shift everything by half when toggled on. When you toggle it off, it doesn’t reset everything back to normal (like all of the other toggles) it just leaves everything in the offset position. If you decide you don’t want it to offset, you have to start over.
Hope this helps, imagine it would be a relatively easy fix.
Thanks!
Running V1.0.04
Thank you for reporting this. If you turn ‘Shift by half’ Off (red) after having it enabled, you need to clear the ‘X Column Shift’ value back to zero if you want to revert back. :slight_smile:
Thanks for the quick response, and makes sense!
