I have a rotary adapter that I have used on an Atomstack A5 m40 and a K40 running GRBL from monport. The rotary adapter needs “Mirror Output to Rotary” selected. And it works “most of the time” but every once and a while the software seems to forget that mirror is selected and not mirror the output. This also shows in the preview window with the output not being mirrored. Opening the Rotary Setup shows the setting is still selected it just doesn’t work. The work around that I have found to work is to toggle the setting off and back on again when this happens and everything is great. I have seen the same thing on both lasers so it doesn’t seem to be related to the device settings. (tested in various versions up to 1.4.0 but as it is an occasional issue it is hard to test)
