With a set of objects with differing priority, selecting the set of objects will show ‘multi’ in Shape Properties. I would expect changing ‘multi’ to 0, or any single number priority would update the individual objects to all have that priority. The input box ‘accepts’ the 0, but the priority of the individual objects doesn’t change.
(also, I swear I really like LB, even though it seems like I do nothing but pick out it’s faults! )
Ah, further testing shows - the bug only occurs if there is more than one object with the priority you’re trying to set. For example, with my set of 0, 1, 2, 0 priorities, I was trying to set all to 0. This fails. If I set the 0, 1, 2, 0 group to 1, the priorities all update.
While working on repeating this… I took a side tangent in my exploration.
I drew six shapes and arbitrarily assigned Cut Order Priority numbers Zero through Eight. Two shapes were assigned priority zero - Two shapes were assigned priority two. Probably not important but documenting / disclosing.
I then selected all the shapes and “Multi” displayed in the Cut Order Priority box.
I clicked the ‘locked’ switch in the Shape Properties Window and clicked it back and the 6 shapes accepted the Cut Order Priority that I chose. I believe that the locked button allows or disallows changes to the Shape Properties but I’m still exploring.
In my mind the negative state of the Locked switch should be Unlocked so, my perception is that the reassignment of multi to a number should take. This is very interesting. I’m going to explore further before reporting.
This gets more and more fun. After arbitrarily reassigning the Cut Order Priority values I decided to lock one of the the shapes when it was set at Cut Order Priority = 2.
I selected all the shapes and the Shape Properties Window showed “Multi” in the Cut Order Priority box. The locked switch showed a new format - a square with a dot in the middle. I hovered over it and it showed ‘Prevents movements or other changes to this shape’. I clicked it - It unlocked - and the switch changed back to its prior slider format and it was green/on
One more time. After arbitrarily reassigning the Cut Order Priority values I decided to lock one of the the shapes when it was set at Cut Order Priority = 2.
I selected all the shapes and the Shape Properties Window showed “Multi” in the Cut Order Priority box. The locked switch showed a new format - a square with a dot in the middle. Without selecting the switch I changed the Cut Order Priority from ‘Multi’ to zero ‘0’. All six shapes changed to priority zero. Including the locked one. Further, the Cut Order Priority of the locked shape had changed but it’s locked status did not.
