Using LB v1.7.03 on a Milling machine where the Z axis home position is the top, therefore all Z values are negative. Everything working fine with LB but if I click ‘Enable Z axis’ when editing a saved position it will only accept +ve values. A negative sign cannot be entered. Tried putting in a positive value in case it sorts it out itself but on testing LB spat the dummy saying the move would go past machine limits.
Have you tried this?
I never tried it but maybe setting a Z offset like I assume you did for X and Y.
Thanks for quick response. The Z axis is working fine everywhere else in LB so the setup is ok. It’s only the Saved Positions tab that isn’t working.
