Bug with v1.7 in the edit node mode
Since the upgrade, when you are in the “node editor” fonction, the shortcuts are no more working. ctrl I open the import file windows, ctrl D is duplicating the whole form, ,same for the others… I work with the french version and an AZERTY keyboard (but D and I are the same with qwerty).
It’s not linked with a specific file, as, to check I created a new file with just a single and simple vector drawing with the pen. The help popup has not changed the shortcuts.
Could you help? Thanks
This seems to be a common misinterpretation regarding the node edit shortcut keys. You don’t need to press the Ctrl key, just the letter keys on their own.
Hope this helps.
thanks a lot it works perfectly. May be a small update to modify the help buble where it is written to use ctrl+
This is what seems to cause confusion. The actual help bubble is correct but is often misinterpreted. Here’s a blow-up:
You’ll see it quotes “Ctrl + `”. This is the keyboard shortcut that invokes the node edit tool and is the alternative to clicking on the Node Edit button.
as you said, it cause confusion :joy:
