I recently went through and did the calibrate camera lens and calibrate camera alignment. Official lightburn camera and holder. All rates were less than 0.20. Did a burn and got this. Even updated the overlay before burning. 20200828_230151|690x388
I turned the lens on the camera initially to bring it into focus after setting the laser head hight. Once it was set before running the calibrations, neither were touched again from start of calibration to burn.
Is the top of the material at the same height as it was when you ran the alignment job?
A good way to ‘spot check’ before you burn is to use the ‘Click to Position’ tool () to jog the laser to various points on the overlay so you can check that it’s lined up. If you clicked the point at the top or bottom, it would be pretty obvious if the laser was off by much.
Everything was the same hight. The dots were glued to a piece of wood to ensure it was perfectly flat. The cardboard that I used to burn the targets with is the same thickness as the wood I burned the image to. I’ll check out the click to position tool when I return home.
