I am having issues when burning wood with my laser. I get burn lines from object to object while the laser is following its path. Example “Coach” will have burn lines from C to o to a to c to h.
Is this a new machine setup for you? If so, the issue is typically due to a GRBL configuration issue with Laser Mode not being enabled. Check value of $32 and set to 1 if it’s not already. You can do this in Edit->Machine Settings.
