Burn not matching graphics in file
So I’m using XTool D1 Pro with LB 14.01 from 8-2-23. I build the file in the photo and did a burn. But as you can see the gear shadows are not where they are all supposed to be and a few letters went wonky. Laser has only been used a few times. It is clean greased and belts adjust properly. Any ideas would be helpful. I have a few shirts to knock out this morning.
This is really interesting. What material are the t-shirts made of?
It may be wise to prove that the fabric isn’t shrinking or moving with the heat.
Would you be willing to do a test-run with MDF, pressboard or even cardboard?
90% cotton and I can do cardboard. I’ll get back to you. I’m also going to check my belt tensions again. TBC.
