Hi All
I have just received an Ortus LM3 and having issue dialing in the settings, i cut 3.2mm ply without any any marks with my LM2-Pro using 100mm and 100%, but whatever speed/power combination i use with the LM3, it leaves burn/scorch marks (no problem cutting), any suggestions?
Hi Jim, that’s the route I’ve been going down, can make it worse, but cannot seem to get clean cuts without marking the wood, tried turning power down to 50% doesn’t cut through, but still marks, and trying speeds 200 through to 500. With focus I can make it worse, just not any better
On Jim’s suggestion i was checking the focus, and on much close inspection, the bean produced seems to be more are a t shape than the usual, also the laser lense appear to have an imperfection, could this be the issue, please see photos.
Has anyone else got an LM3 they can compare to tell me if this is normal (have logged a ticket also with Gil, so hopefully get an official response soon)
