I was burning a leather key chain 1.25 high 2.5 width. I am burning in inches. the only thing I did was size a circle in mm to add in the key chain. It went from 6 minutes to 2hrs 46 minutes. All of my settings are1 pass except the cut.
Lightburn works internally with mm, so even if you switch from mm to inches it’s converted from mm and displayed in inches.
I can’t see how this could effect it the way you describe.
If all you changed was the circle, you can delete it and see if it solves the problem.
You can ^Z and remove the previous edit (deleting the circle)…
If you’re willing to share the lbrn or lbrn2 file it’s possible that we may see a reason for the additional circle being so time consuming.
