Burning pics on acrylic?
Is it possible to burn on acrylic
what do I have to think of
Kristian
Diode laser will not burn on clear or most transparent color acrylics. Colored acrylics at the blue end of the spectrum will not take marking. Marking with a 3.8w diode will also be marginal.
The only accurate answer for your machine is to do some testing.
@MikeyH is pretty much right. If it’s dark enough acrylic, then it’s likely too dark to use it as a light pipe, if that’s what you have in mind.
I’ve done a few on acrylic, but there very little range of grays, so you have to use a dither of some type. The only practical way is to use a coating you can heat up and it will heat up the acrylic. This is referred to as an indirect method.
If you burn away the coating, the laser power will just pass through the material.
:grinning_cat:
I have done black with the paper still on it with pretty good success even for a new guy.
As already mentioned, using a laser diode machine (visible light) on acrylic is complicated, but something can be achieved.
I’ve been through this before, and if you do a search you’ll find a thread I started at the time about the subject and the result I achieved.
