Hello everyone. So first off I’m not as savvy with computers as I probably should be. So my challenge is probably a very easy one to fix. 100w r&b omtech. HP laptop running windows 10. Open office for my word doc.
So I’ve made a logo In Lightburn.
But not I can’t seem to convert it so I can then use it in a Word doc. So I could make business cards or other things.
What’s the trick to converting from lbrn to like png, jpeg. Something that I can use I word documents.
For something like a logo it would be preferable to save this as a vector file type like SVG.
I don’t know if Open Office natively supports SVG import but I do believe they have plugins that will support it.
It should import PNG images without a problem.
To export SVG:
select relevant objects for export
File->Export
pick relevant file type and name for exported file
To export PNG:
Edit->Convert to Bitmap
File->Save Processed Bitmap
Pick relevant file name and include file type extension in name (e.g. image.png)
Note that you can use right click on the select objects to achieve steps 2 and 3 as well.
I’ll caution that LightBurn is not an ideal tool for creating images as you have essentially no control over color and very little control over rendering of the image.
