I apologize if this question has already been asked and answered (I did a quick search and did not see it)
I am currently using LB 1.4 with my CO2 laser and now I am buying a Galvo Fiber laser. I know that I will need to purchase the Galvo license for LB. My question is will I need to run two versions of LB on my computer or can I run both lasers from a single instance of LB?
I switch between the little diode, the China Blue co2 and the fiber in a single instance of Lightburn⦠itās in the device settings that lets you determine specific hardware type requirementsā¦
Make sense?
When you have questions, sing out⦠none of us got these out of the box and working without questionsā¦
By design, LightBurn allows one to define (step 1) multiple āDevicesā or device profiles and select (step 2) the one you are keen to work with for a given job. All from a single instance of LightBurn.
My Galvo fiber laser finally arrived. I just purchased the Galvo add on license (for existing DSP license).
I deactivated the license on my Lightburn, restarted entered my license number and Lightburn 1.4.0 started as normal. Everything looks exactly the same. How do I know if I have the Galvo license added correctly? Do I need to download a new version?
When I search for new devices it only finds my existing DSP CO2 laser, does not see the fiber. I have the fiber turned on and the USB cable plugged in.
There is one last question on setup, when I opened one of my existing LB files all the graphics were shown upside down. When I engraved them on the laser they were correct. So I suspect I have something inverted in the settings. I imported all the EXCAD settings so not sure what needs to be changed.
