I’m all new here, found this forum after reading lot’s of stuff and understood that LightBurn is the way togo software vice. So I though what better place to ask for serious advice than here.
I’m looking to purchase a laser cutter to work on acrylic up to say 4-5mm and all other stuff you can do, including engraving. I need at least a 600x400mm cut area.
My budget is around $2500 but I’m flexible for the right machine. I would take a smaller, higher quality machine over a larger with less quality.
There are a cornucopia of topics on that subject here. Do a search and you will find what the thoughts on the subject are. I would suggest a laser no less than 80 watts if you are going to be doing production work.
Here is the 100 watt version of the laser I have by the same distributor. I own the 60 watt version. They are known by Orionmotortech or Preenex. Look at the pictures and comparison chart.
