Bonjours , je n’arrive pas a accéder aux calibrage de l’axe , j’ai la version 1.403 , j’ai une différence de 5mm entre le logiciel et la machine
I believe the Commarker b4 is a galvo type laser. There are no machine settings option.
Each galvo lens has to be calibrated.
The following You Tube playlist is well worth a watch and does cover everything you will need.
