I just downloaded the latest version to use the Calibrate Galvo lens feature. No matter what size I set my working area of the lens, it makes the same size square when I frame it. Advice?
You don’t have a choice… as far as I know… this size is based on the lens.
After you calibrate the lens, it should be right… One I did with the EZCad software came out a bit smaller than it should have… however the lens shows no distortion…
Ensure it’s focused and run the operation…
There is a video that someone has done on this… I haven’t watched it, but it’s supposed to cover this…
Maybe @Rick can help with this… I haven’t used this feature as it’s new in Lightburn…
