Firstly, can i just say how awesome lightburn is. RDworks is a nightmare for new users, lightburn is a dream <3, so much so i just purchased a license and a camera
I have a 900x600 Chinese laser with a Ruida RDC6442S-B controller and this is the stepper motor:
Hi Ray, so finally got around to sorting this out, and 100%, with a bit of guess work, i got there. Its good enough hey, i can make this work for what i need!
To the eye, it looks fine… is there a mathematically way to calculate this?
In RDworks, there is a measurement vs. graph length setting, where i can enter the actual value of the cut / shape. Is there a setting somewhere like this in RD works, that re-calibrates the software to the cutting bed on the machine?
In LightBurn, you’d go to Edit > Machine Settings and click on Calibrate Axis at the bottom, but this is only for the X / Y Z / U axis, not the rotary. We could likely do something similar for that though.
The formula is as follows:
New Steps = Old Steps / measured length * intended length.
e.g.: You want to cut 100mm but get 105mm (meaning your current steps are too hight) and your current steps are 200:
New Steps = 200 / 105 * 100 = 190.476190
Question I have is when you change to a different diameter cup if you enter the diameter in lightburn do you still have to go through the process of finding the steps per rotation or once you know it for one size does it calculate it for you? I dont use lightburn but am interested in it and if it makes this process easier I may switch is why I ask.
