We have a new 8 lightburn camera. When I open up the lightburn software and select to calibrate, the window is so darn small that I cannot see clearly enough to do the calibration.
Is there anyway to make the window bigger so I can see more clearly?
When you click Next you’ll have more of the window opened up. Are you running this on a Microsoft Surface or something small with a really high density display? Or do you have font scaling turned up a lot?
Regardless - grab any corner of that window and you should be able to drag it larger.
That window is normally much larger, but I don’t have a good sense of scale from the image. It also appears you have the lid of the laser closed - you’ll need to open it.
