Calibrating speed y axis
Hello I am using a k 40 laser with smootiebord, 0.9.14 but am having problems installing Lightburn with camera.
The following problem occurs,
Calibrating out of camera alignment does not work correctly.
When burning 1 to 4 the following happens, 3 and 4 burn perfectly, but as soon as the y axis moves to 2 the belt slips and 2 is burned too low.
Moving the y axis from position 3 to position 2 is so fast that the belt slips.
can you slowdown the y axis?.
In normal use, the belt never slips at all
Never had any problems before installing a smootie board.
