i spent 2 hours wrong with this. i can calibrate it fine. shows up fine even burned the corners and numbers . but after that. it is off set. its like the cam is mirrored . i place something on table. take a snap shot. run a test and it cuts on the other corner. also the cam is not showing everything on table. making my burn table size smaller. i have a atomstack with a 20w lazer. runing on windows 10 and a cooling vent and led lighting. < no shadows in cam.setup >
