Calibrer ma rotative sculpfun imposible - Unable to calibrate my Sculpfun rotary attachment
bonjour je viens d’installer ma rotative a rouleaux scuplfun comme indiqué mais l’axe Y ne tourne pas, le moteur fait un drole de bruit, il vibre.
j’aurai oublié de faire une manipulation??
Hello, I have just installed my Sculpfun rotary roller attachment exactly as instructed, but the Y-axis is not rotating; the motor is making a strange noise and vibrating.
Could I have forgotten to perform a specific step?
Then you probably used the wrong cable. There are usually two, labeled A and B, if you use it on a Sculpfun system, you need to use A.
Merci pour ta réponse, et c’est exactement ça je viens de faire se que tu as dit et ça fonctionne merci a toi.
Thanks for your reply—that’s exactly it! I just did what you suggested, and it works. Thank you!
