Cambio de velocidad en ikier k1 (Gear change on ikier k1)
Tengo una IKIER K1 Pro conectada al Lightburn 1.4.00 mediante el controlador grbl-lpc.
La velocidad de desplazamiento en vacío es muy lenta y me gustaría aumentarla. Como lo hago?
I have an IKIER K1 Pro connected to Lightburn 1.4.00 via the grbl-lpc driver.
The idle speed is very slow and I would like to increase it. How do I do it?
Idle speed, or G0 rapid speed, is determined by the maximum feed rates as factory configured in the GRBL parameters in the controller firmware.
These parameters are editable if you connect to the laser and then navigate to Edit > Machine Settings, look for;
X Max rate (mm/min) ($110)
Y Max rate (mm/min) ($111)
If you make any changes, click on ‘Write’ to update your machine settings.
Then I like to click on ‘Read’ to confirm the settings have been changed.
Note of caution, increasing the idle speed beyond the factory prescribed settings may not lead to better results, and can cause positioning errors.
Ok.
Thank you very much for your help.
Kind regards
