I have a Longer B1 that has the extension kit on the Y axis. I jave their camera which is made for the standard 440mm x 440mm area. I get the Calibrate Camera Lens done but when I go to set the Calibrate Camera Alignment and hit frame, it centers it in the Y axis so I only see half of the framing on my camera screen. Any ideas on how to set the areas to match?
Create your laser again with a 400x400 workspace. Then you can switch between full workspace and half workspace + camera. See a detailed explanation here:
Ok, yeah that makes sense. I guess I really only need that area seeing that the camera has to be a certain distance from the work space and limits to the dimensions of the non extended B1. Thanks!
