Hi Aaron
Lightburn Camera Alignment
To try to be as comprehensive as possible I created 35 images as i progressed through the process - unfortunately after adding them all to this post and pressing submit the forum portal said I could only upload 4 - so have placed figure numbers where the images should be and I will email you the PDF. Not sure if you also want that info available to other members too to aid cklarity
to recap
I am running windows 11 and Lightburn (v2.1.03) and cannot thus far correctly align the camera
Also of note, there are 2 USB cameras on my PC -which is relevant further down when camera selection is reached - unfortunately windows has labelled them both “USB camera”
- A webcam used for video calls above my display
- The USB camera mounted above my device
Remove existing camera from lightburn
Close lightburn software and restart it
On restart this window popped up – have restarted lightburn previously and have never seen this message before
Figure 1
Device seems to be “Homed” by lightburn at startup – there is no camera added at this stage. Workspace dimensions show correctly as 290x170
Figure 2
Device Settings
Figure 3
Figure 4
Figure 5
Figure 6
Machine Settings
Figure 7
Now adding the camera
Laser Tools > Manage Cameras
Even though I had previously removed the camera the USB camera was in the list – so I removed it again
Select the USB Camera and press “Remove”
Figure 8
Now the list is blank but the camera control window is still streaming live
Figure 9
I pressed “Add New”
Figure 10
I pressed “Select” for the USB Camera
Figure 11
Figure 12
The camera listed here is the webcam above my display screen – even though I removed the overhead camera from lightburn it was not listed here and yet the camera control screen is still showing a live feed from the overhead camera – something weird going on.
I closed the manage cameras dialogue window and pressed Manage Cameras again
Figure 13
The camera has appeared in the list again without me adding it - weird
This time I selected the camera and pressed edit and got this view
Figure 14
I repositioned the target piece of material so that it was aligned with the front edge of the bed
I then pressed “Align to Workspace” button
Figure 15
Figure 16
Figure 17
Figure 18
On this screen I used machine control to adjust the height of the z-axis to be 5mm above the material surface and set power to be 45%
Figure 19
Once finished I clicked on Next and got this view – no camera image at all!!
Figure 20
I tried to click back then Next again – still no image
So I kept clicking back until I came back to this screen again
Figure 21
Then I clicked the following (ive not included screenshots since its a repeat of those steps above just without the burning of the pattern this time)
“Next” on the welcome screen
“Next” on the select alignment screen (manual chosen)
“Next” on the Manual Alignment Wizard screen
“Next” on the Alignment Pattern Setup screen (parameters were as before 20, 290, 170)
“Next” on the Burn Alignment pattern screen (without burning this time – the material was in exactly the same position)
Now I get this screen with the camera image – note that the laser module is back in its home position
Figure 22
I used the machine controls to get this view
Figure 23
Note that the number 4 in image top right corner is physically in front right corner (ie home position)
Then I clicked each number in turn and then “Next”
Figure 24
Figure 25
I must admit that I do not know what is meant by “Verify that the alignment is correct in the warped preview”. I mean it looks OK – it doesn’t fill the complete workspace but now the number 4 is in bottom left which I presume is the home corner and corresponds to the physical front left bed.
I am open to having misunderstood the meaning though
I clicked next
I have just noticed that on all previous alignments after clicking on the 4 points the alignment process asked me to draw a rectangle covering the useable area – it did not ask for that this time
Figure 26
Then click finish and then finish again to exit the “Edit Camera” Dialogue
Figure 27
Then “OK” to exit the “Device Cameras” Dialogue
This is the main window view with camera control tab open to right side
Figure 28
Since the main Lightburn window does not show the camera view of the bed I then pressed the “Update background from the Camera” button
Figure 29
And get this view – which actually looks promising since the main window and the camera control view are the same (feeling hopeful…)
Figure 30
So I drew a square around the arrow near bottom left corner
Figure 31
And in the laser tab I pressed frame to see if it positions the frame correctly on the bed
Success!! (feeling very hopeful..)
Not satisfied I moved the square to cover the 3 in front right
Success!! (now getting giddy with the success..)
I will close Lightburn and re-open without changing anything or moving the material
On opening Lightburn it homes the laser module
This is the view with camera control tab open
Figure 32
Then I pressed the “update background” button and its looking good (now holding my breath..)
Figure 33
I drew a square around the “4” and pressed frame
Figure 34
The “Frame” is approx. 80mm “above” the target (ie Y axis) marked by the red lines. The x-axis looks about right. I didn’t want to disturb the material by measuring more accurately.
Figure 35
Must admit to feelings of deflation and somewhat turning the air blue - but no-one else heard so that’s ok
any suggestions for next moves - or if I’ve have missed anything interpreting the instructions
regards
dave
